westend
Aug 13, 2014Explorer
What is AC noise?
EDIT: you described what your issue is while I typed. There should be no RFI or EMI issues between your RV 12V system and the truck's alternator. The power circuit from the truck to the trailer is terminated through the truck's battery which is a big filter. You may get some spurious RFI into radio frequencies but nothing that would cause your senders to go wonky.
It sounds like your RV's battery is bad and the loss of current may be your major issue.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 26, 2026
