BBB196's avatar
BBB196
Trailer disconnected message on F150
My TV is a 2015 F150. The issue I am having is while towing the recently acquired used TT (2018 Coleman 215BH) I am constantly getting dash message showing "Trailer Disconnected" along with Trailer gain 0 messages. Mostly when I'm slowing or accelerating, not once I get up to cruising speed.
If you are familiar with the F150 forums you will know that this is a common issue, but most people over there say it's usually due to an issue with the trailer grounding or brakes.
So here comes the dumb question.. I got to looking at the tongue of my trailer and noticed two wires just hanging by the battery which are not connected to anything, one of which is white and appears to be a ground wire. The other one is blue, and is coming out the bottom of the front of the trailer with a fuse hooked to it.
As you can see, the negative from the battery is grounded to the frame on the right side of the photo. Am I correct in assuming this hanging white wire here is supposed to be connected to the frame and is probably the reason my truck keeps giving me these messages? TIA
  • Just wanted to post a follow up for anyone who looks up this thread in the future. Cleaning the connectors didn't do anything. I ended up having to take my camper in for service on an unrelated issue so I had them look at this problem as well.
    They told me there was a loose wire on the trailer brakes which was causing the issue. Several camping trips later it hasn't happened again so I guess they were right.
  • Thanks for the responses guys, I appreciate it. I did determine those extra wires are for the solar charging port. I will try cleaning the connectors and hope that helps the issue. I guess I need to get under the trailer also and check the wires on the brakes.
  • I had the same issue with a F250. With trailer wheels removed, they found brake wire insulation had worn and shorted out.
  • Try some electrical cleaner on both truck and cord connection. I had the same problem. I now put some dielectric grease every now and then. Haven't had any more problem.
  • Those 2 wires look same as mine, 2019 Coleman 17RD, may be for the solar charging. At the front passenger side of the trailer, there's a square receptacle with a lid about 3 feet above floor level, open it and there's a round plug inside. That's where the exterior solar wires are supposed to go. The white and blue get hooked to the battery. Why Coleman did that is beyond me, just hook the solar up through the controller and then to the battery. Simple test, use an ohm meter on the blue wire to the receptacle I spoke of.
  • Bobbo's avatar
    Bobbo
    Explorer III
    1. Trace the wires to see where they go.
    2. Edit your post and put width=640 just before the closing {/img}.
