neu
Apr 28, 2023Explorer
Reisender wrote:neu wrote:Reisender wrote:
Not sure if it’s a Q7 or not. I helped a fellow setting up his Q7 for a T@B 400. The tow info table covered a few configurations and went from 4400 to 7700 pounds towing capacity and 440 to 770 pound hitch weight. He had no problem with the T@B but don’t know what this trailer is for weight. Point is it may be fine depending on the cars options. A weight distribution hitch was specifically not recommended so probably not an option for the OP.
This is a Q5, but I understood the essence of your message, thank you.
Hi Neu. Probably best to weigh the hitch after it’s loaded as well. Some trailers get quite a bit heavier on the hitch after battery and propane are added. Try to pack accordingly to keep the hitch weight under control. Front storage compartments are nice but if you are struggling with hitch weight maybe pack the light stuff up front.
Happy camping. :).
Thank you! You too!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
