neu
Apr 29, 2023Explorer
bikendan wrote:neu wrote:bikendan wrote:nickthehunter wrote:
It’s a single axle trailer; I’d be more concerned about the payload rating and tow rating of that car vs. the tongue weight and GVWR of that trailer. Clicky
Totally Agree! I'm betting that the loaded tongue weight is exceeding the car's max hitch weight.
I have an Audi Q5 2018 and according to the specifications, it seems to be capable of handling a 440-lb tongue weight.
Can the 2018 Audi Q5 Tow?
My trailer is called a Viking Saga 16sfb 2017, and I cannot find the specific characteristics for my year of production. However, for the new models of 2022, the Hitch Weight appears to be 363 lbs. If I understand correctly, this falls within the specification range.
Specs for 2022 Coachmen - Viking Saga Floorplan: 16SFB
The towing capacity of my car is 4,400-lb, which should be enough to cover the GWVR of 3,675-lb that my trailer has.
Please correct me if I am wrong about anything. It's all new area for me
Single axle trailers have much higher loaded tongue weights. Using the standard 13% of the trailer's GVWR, for a ballpark loaded tongue weight, puts it over 500lbs. NEVER believe fictitious brochure/website dry weight numbers. They don't factor the weights of batteries, factory options, dealer add-ons, water and trailer cargo. Once you add the weights of those things, the tongue weight really goes up.
You need to weigh the trailer's loaded tongue weight. And you didn't post what the payload capacity of your car is. Should be on a driver's door sticker.
Thank you, that's valuable advice, and I'll definitely take it into consideration.
However, I still have doubts about your statement that the manufacturer has provided an incorrect weight. One of their main tasks is to distribute everything evenly in the trailer, so that the weight is balanced on both sides of the axis. There's quite a bit of furniture located behind the axis in my trailer, and I don't think it's a coincidence - everything has been calculated and thought through. Even if the manufacturer doesn't take into account the weight of the propane cylinder and battery, I can easily detach them and load them into the trunk of my car.
You're a bit off with your calculations: 13% of my trailer's weight is less than 500 pounds, and to be precise, it's 477 pounds. As far as I understand, the tongue weight should be in the range of 10-15% of the trailer's weight. 10% of 3675 lbs is exactly 367 lbs. So, it looks like I just need to keep it within the range of 367-440 lbs to stay within the allowed limit for my car. As I understand it, I can always put something heavy in the back of the trailer (like a bottle of water, for example) to adjust the weight and keep the tongue weight within the desired range. Remember, all the calculations we made based on GWVR, so If I drive with empty tanks I should be below the limit definitely.
According to the sticker on my driver's door, my car's carrying capacity is 480 kg (1058 lbs), but I'm not quite sure why we need to consider the carrying capacity of my car. What does it have to do with this equation?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
