Reisender
May 01, 2023Nomad
neu wrote:Reisender wrote:nickthehunter wrote:Reisender wrote:That is advice that can take you directly to the scene of the accident if you are not careful. It is worth mentioning that it is essential that you keep at least 10% tongue weight, and preferably 12%. Not doing so can be catastrophic.
…Try to pack accordingly to keep the hitch weight under control. Front storage compartments are nice but if you are struggling with hitch weight maybe pack the light stuff up front…
Absolutely. Hence the recommendation to weigh everything. But in my experience single axle trailers with batteries on the front and large front storage compartments can result in overly heavy hitch weights. It’s just something to keep an eye on. In North America they recommend 10 to 15 percent whereas in Europe they recommend 6 to 10 percent for hitch weight. (We have a European designed trailer but built in the US). Best to try and pack over or close to the axle. Many European designs have things like fridges, batteries and storage areas as well as water tanks on or around the axle. Works out well and loading the trailer has less of an affect on the hitch weight. Ours is like that. Our hitch weight actually is slightly less when fully loaded although still at that 10 percent mark.
The absolute worst thing I see is these cargo racks on the rear end of trailers. Horrible idea.
Now I'm a bit confused by the numbers you provided as an example :h I just watched a video that emphasized not to let the trailer tongue weight drop below 10%, otherwise there's a very high risk of getting into a fishtail situation. At the same time, you say that in Europe it is NOT ALLOWED to exceed 10% for safe driving. So which of these statements is correct?
In Europe it’s different. Most trailers are pulled by cars and there are speed limits on cars pulling trailers. As well weight distribution hitches are very uncommon and frowned upon. You can google for better clarification of their rules. But North America you will commonly see a recommendation of anywhere from 10 to 15 percent for hitch weight.
Cheers.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
