Grit_dog
May 02, 2023Trailblazer
Reisender wrote:nickthehunter wrote:
Throwing Europe into the mix is a distraction away from the real answer. What he’s saying is, 10% or less is ok if your not going to exceed 45 mph. If you want to drive at a reasonable speed, your going to need a reasonable tongue weight. Most reasonable people would agree that’s not less than 10% for sure, and better yet 12%.
Yes it was just for context. Stick with 10 to 12 percent and try and pack heavy items close to the axle.
Or more succinctly, tongue weight is still just a rule of thumb and the only 2 things that matter is that it’s not excessive (for whatever limiting factors may apply first) and that the trailer pulls straight and true.
I’ve pulled a lot of fairly heavy trailers (2k- maybe 8klbs or more) that have virtually zero tongue weight by design. Even those, some pull just fine, some get the wiggles at highway speeds.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
