wa8yxm
Apr 06, 2016Explorer III
Is your fridge a Dometic?
here is why I ask....
Dometic Units have a terminal board that is often on the bottom of the outside compartment.. This is where the AC cords connect.. there is a "Drip tube" that is SUPPOSED to be put out via a vent hole in the outer, lower cover so it drip, drip, drips on the ground.. on my Rig I found the dealer left it inside the compartment.. When I had the Dometic recall done I mentioned this to the consultant, the technician said "I always put it out" Well.. when I got back to the RV post recall.. It was not out again.
Next, the plastic tube can crack and leak so it drips down inside as well.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
