bcarroll
Apr 06, 2016Explorer
Ok. Did some additional testing.
It is a Norcold fridge.
When I unplug the fridge, there is power to the outlet it is plugged into.
When I plug the fridge directly into the extension cord, it still does not work. I have an "Auto" setting and a "gas" setting on the fridge. If plugged into power on auto it will/should run the fridge on electricity; if no power is detected it will run on gas. There is a light that should light up, but it does not. Neither does the gas run the fridge.
I tried it on the "gas" setting(making sure the propane tanks were turned on) and no light there either, no trying to ignite.
Disconnected the GFCI outlet, turned on the GFI breaker, and it still tripped the GFCI outlet in my garage.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
