bcarroll
Apr 10, 2016Explorer
Just as an update... I just came back from a camping trip, and while plugged into the campground power, I truned on the GFI breaker and... it seems to have worked. Nothing tripped a breaker, blew a fuse or caught fire so I assume it is ok.
I still will take it in to a repair place tomorrow to have it checked out by someone who knows what they are doing.
(the first thing this placed asked me to do, when setting up an appointment, was to plug it into a non-gfi outlet - which I did not do until the campground).
Not sure what this means other than I may not be able to continue plugging it in to the same outlet I've used for the last 2-3 years.
I do have a hand held meter but not sure how to use it other than testing the volts in my batteries.
Yes, you are at the start of a new problem. Since you're not that conversant with electrical systems, advice about working within the loadcenter may be hazardous but that is where a diagnosis of your issues could start. I'm guessing that you don't own a hand held meter?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
