scottsnider's avatar
scottsnider
Explorer II
Jul 25, 2016
Trailer running lights
I have a 2010 coleman hybrid trailer and heres the problem, the break lights work and turn signals but for some reason not the running lights. Yes they did work back in April but not now and I have cked fuses in the trailer although I did not think that would be were the problem was. On my last trip my plug did some dragging so I have to replace it and hope I will find some lose wires are the problem but if not any suggestions? Since I knew I had a problem I did add extra reflectors on the trailer just in case but kept driving at night to a minimum and no Highway officer stopped me. So any ideas?
  • 7-pin Bargman Pinouts ... +12 vdc required on Pin 3 for the running lights to illuminate.
  • I suggest you start by checking the trailer connector on the tow vehicle with a test light to verify that each of the terminals is functioning correctly. Then at least you know if the failure is in the tow vehicle or the trailer.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
