Old-Biscuit
Aug 30, 2015Explorer III
120V AC power comes from shore power source.......pedestal etc.
Goes thru your 30A rv power cord to Main AC Power Panel thru the 30A MAIN Circuit Breakers.
AC Power Panel buss is hot when Main 30A CB is Closed.....then the individual circuit breakers feed the various AC equipment when they are closed.
SO if you have 120V AC power at pedestal and thru cord to AC Panel and CBs are closed then AC appliances and outlets should be hot
Unless you have a generator... which gets plugged into outlet where rv cord is OR a transfer switch that is stuck on 'GEN'
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
