westend
Aug 31, 2015Explorer
He doesn't have a detachable cord.
Are you comfortable removing the front plate of your load center and delving within? Off hand, I'd say you have a connectivity issue.
Remove shore power cord from power source. Carry shore power cord male end into RV. With the front panel of the load center removed, you should see the neutral buss bar that has a few white wires held by screws into that bus bar. Place one meter lead onto the neutral prong of your shore power cord and the other meter lead onto the neutral bus in the load center. With a meter set to resistance, continuity, ohms, you should have complete continuity with nearly no resistance, maybe a fraction of an ohm. If there is no continuity, you have a problem within the cord (most likely) or an issue with the neutral connecting to the bus bar.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
