joe0508
May 10, 2014Explorer
trak bar
Are there any track bars out there that will hook up some other place other than the u bolts for a 92 p30 chassis.
j-d wrote:Is it just a simple matter of just taking the bolts off the clamps and installing the axle mount.Than put the original bolts back on.Would there be no jacking involved and will everything stay in place after taking bolts off the clamps.
I'm not exactly sure which Track Bar Joe's coach calls for. Some operate on the assumption that enough U-Bolt length sticks through the bottom plate that the axle mount for the track bar can go over the ends and still room for nuts to hold it in place. Another bar that I looked at on-line came with U-Bolts but I couldn't tell if they were to add the bracket separately or to replace the originals with longer ones.
The spring pack itself should have a Center Bolt through all the leaves. Those bolts have a head that's meant to center the axle in a bracket. Some mechanics recommend new U-Bolts if you've taken the old ones out.
