time2roll
Nov 14, 2017Nomad
If you are holding down the contact to make it work it is not the contact itself. It is either the control module or the coil in the relay. Are you sure you have power on both L1 and L2 of the source?
However in the normal closed position the relay should pass power from one source or the other based an where the relay is stuck. I recommend a complete new switch.
http://www.bestconverter.com/100-Amp-Transfer-Switch
