mikathi
Nov 17, 2017Explorer
You said, "Yes you can wire nut one source to the output. Put wire nuts on the second power source to isolate the wires as disconnected." I've not done this before but do know enough about electricity to be dangerous, as they say. Wire nut one source? Are you referring to wire together only the L1 and neutral? Not both L1 and L2? I've already wired The L1's together L2's together and the Neutrals together. Now the converter will not come on. Do i need to disconnect the L2's. Otherwise I'm just going to put it all back together until the new switch arrives. At least I was able to get it to run for a few hours. better than nothing. HELP!
