As som off you know my MSH3012 inverter won't pas true power so I have to have a bypass switch installed. The electrician her in Australia are not clear on how to do this so can someone please supply ...
Not clear about a few things. 1. The Magnum OUTPUT is 60htz. So, when on Invert your frequency will NOT be 50 htz but 60htz which will cause certain motors and such to run faster 2. Are you adapting a USA built RV to Australian current? 3. Have you tried to find a Magnum with 50htz operation? This would be the best solution 4. If you have a USA built RV, what about operating all the 120/60htz appliances 0n 50htz? Is that OK? Doug
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
