As som off you know my MSH3012 inverter won't pas true power so I have to have a bypass switch installed. The electrician her in Australia are not clear on how to do this so can someone please supply ...
We really need more information to assist you. Let's start with what appliances are on your RV-- are they designed for 120VAC/60HZ? That could be a problem right there if powered by 50HZ.
And, if your appliance are 50 HZ, unless you get a 50 HZ inverter, when on inverter power, you will be supplying them with 60 HZ, not 50 HZ.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
