As som off you know my MSH3012 inverter won't pas true power so I have to have a bypass switch installed. The electrician her in Australia are not clear on how to do this so can someone please supply ...
I don't plan on use the mains 50hz to supply it but a 110V 60hz generator. Can anybody explain if I can use a bye pas loop wit 2 way switch when on mains power and supplying the inverter with a generator on the other setting. Thanks Frank.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
