As som off you know my MSH3012 inverter won't pas true power so I have to have a bypass switch installed. The electrician her in Australia are not clear on how to do this so can someone please supply ...
It already has a step up and down transformer for the 220V but as it is 50hz it will not activate inverter. So only want to be able to run with 110V 60hz generator or or of batteries. The drawing I supplied will this work ?or can someone please supply one that would without back feeding in to inverter. The power coming to junction box or toway switch will always be 110V only differens is 50-60hz. Thanks Frank.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
