Sure. A few wire nuts and connect hot-hot, neutral-neutral, ground-ground. Depending on the configuration you might be able to use the internal connectors to bypass the relay.
Open the cover and pull the wires off.
Just connect the generator to the wires that feed the main panel. Do not connect the cord to the power.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
