time2roll
Jul 25, 2013Nomad
Just plug the shore power into the generator to power the entire panel.
Then move the circuits you want inverter only to a subpanel. The main panel and inverter will feed the transfer switch sending power to the sub panel.
If the inverter needs to only power one or two circuits you could just use one transfer switch for each branch circuit.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
