n4hwl's avatar
n4hwl
Transmission fluid additive in the hydraulic system
I wonder if there's a transmission fluid additive that would soften the seals on the jack cylinders without hurting anything. Has anybody ever tried this on HWH system. I have a left rear jack that is moving slowly going up. It's still working and transmission fluid on the cylinder before it goes up does help a lot. I know it's a matter of time before I have to get another cylinder but just trying to prolong is life.
Ken
  • Doug
    When the jack stuck 1 inch from the top I reached under it and was able to easily push the jack up in place with my hand.
    Ken
  • n4hwl wrote:
    Doug
    Ken
    Replace all 8 springs. 2 per jack. Doug
  • dougrainer wrote:
    1. HWH is ADAMANT to NOT use any additive in the system
    2. Under warranty, when the seals stick. HWH replaces the cylinder, NOT try to do silly things like polish the cylinder or wipe it down with something else or add an additive. ALL that does is temporarily stop the problem. It comes back in a few weeks or a month.
    3. The problem is the seals have stiffened up and only a rebuild or replacement with the new style seals will fix the problem
    4. If you want to know if springs are your problem
    1. If they are NOT rusted and both ends taper up to the hook, your springs are OK
    2. When you retract, with NO springs, you can easily push the cylinder fully up. If you suspect the springs, when it stops, manually push it up. If you cannot, then springs are not the problem. Doug
    I couldn't agree more with Doug. Spot on. When hydraulic systems fail to operate correctly, it's rarely because they need a "Genie in a Bottle" or a magic wand. Find and fix the problem. Unless you want to be like one of my more memorable boon docking neighbors who couldn't get his jacks to retract from fully extended position with the front wheels off the ground. It's not a problem that a few days and a few $$$$'s won't fix.
    Chum lee
  • "I know it's a matter of time before I have to get another cylinder but just trying to prolong is life"
    _______________________________________________________________________
    "Brake fluid swells neoprene. But I warn you, this is a tourniquet not a health spa treatment"
    ________________________________________________________________________
    Amazing how the English language morphs ;)
  • I installed new springs to the slow jyack. Now it goes up quicker than the other on on the rear. This new spring is made different than the old ones.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
