WyoTraveler
Jul 11, 2013Explorer
Years ago I added a tranny temp gauge on my 1989 Pace Arrow MH. Fairly easy job. I drilled a hole in the pan. (Remove it first) Make sure where the hole is drilled there is enough room for the probe inside the tranny. Some are pretty tight in space. I had a nut welded to outside of pan with same threads as probe.
