bsmith95610's avatar
bsmith95610
Travel Trailer Brake light wiring
Hello,
I was working on replacing one of the brake lights on my travel trailer. I unscrewed my old brake light and thought I would use one of these butt splice connectors for connecting my lights but then I realized that these won't work since some of the current connections have three wires. I wasn't sure what the best connectors are for connecting three wires? I was thinking I could use wire nuts with electrical tape but that probably wasn't a good way. Should I use the T-Tap wire connectors like this since this is what was there previously?
Then I had to remove some white foam from the wires before I could get to the connectors. Once I get the wiring completed should I probably spray some of that foam back in there to make it more water proof? If so should I use something like this?
Any help would be much appreciated.
Thanks
  • I guess I'm confused...why can't you use butt conectors?
    I use them all the time...use the "shrink" style ones for a water tight seal.
  • I have used those T Tap connectors before and they have always worked well. For moisture protection I use shrink tubing or liquid tape.
Having RV issues? Connect with others who have been in your shoes.24,359 PostsLatest Activity: Feb 07, 2026
