CantCampEnuf
May 14, 2015Explorer
ScottG wrote:
It should be wired directly to the battery. Sounds like it is wired to the converter and has a battery disconnect switch between the conv and batt. Or the battery is not in the circuit for some reason - check its wiring.
If you have a disconnect switch, make sure it's on.
I will look for that. I would think if the disconnect switch was engaged, that nothing would work? Thanks for response.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
