ScottG
May 14, 2015Nomad
CantCampEnuf wrote:ScottG wrote:
It should be wired directly to the battery. Sounds like it is wired to the converter and has a battery disconnect switch between the conv and batt. Or the battery is not in the circuit for some reason - check its wiring.
If you have a disconnect switch, make sure it's on.
I will look for that. I would think if the disconnect switch was engaged, that nothing would work? Thanks for response.
Yes, exactly. I take it the lights and what not work when the trailer is disconnected from both the truck and shore power?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
