joe0508's avatar
joe0508
trik l start
Does anyone know if you can hook two 5 amp battery monitors up at the same time.I ordered one and they ended up sending me two.Can i use them both at the same time to get 10 amps instead of 5 amps?
  • wolfe10 wrote:
    Simple answer-- install just one, as 5 amps is plenty to keep your chassis battery charged (obviously with the house battery charged by external source).
    Adding the second one would charge the chassis battery faster if deeply discharge (again from the house bank), but totally irrelevant in terms of maintaining level of charge.
    Thanks
  • Simple answer-- install just one, as 5 amps is plenty to keep your chassis battery charged (obviously with the house battery charged by external source).
  • WILDEBILL wrote:
    A little more info on what you are trying to do. Unless shown differently 2 5 amp monitors are 2 5 amp monitors not 10 amp.
    Bill
    I have two 5 amp monitors.Can i hook them both up at the same time?
  • A little more info on what you are trying to do. Unless shown differently 2 5 amp monitors are 2 5 amp monitors not 10 amp.
    Bill
