Joel_T
Feb 06, 2017Explorer
To see what your panels are putting out get to "SOL" mode on your trimetric. Then turn on enough loads on your batteries so the battery voltage gets below 13 volts. Then your panels will be pumping max amps which you can observe on the SOL display.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
