brulaz
Feb 10, 2017Explorer
Almot wrote:brulaz wrote:
My Rogue (and PD charger) only does 2 stage.
But at least the Rogue allows me to set the amps cut-off for absorb stage as well as the time.
If this is the Rogue I know - it is a 3-stage controller.
Bulk - amps and volt rise, Absorb - volts are constant and amps are tapering slowly, and Float.
Yes that's the one. But some (e.g. US battery) don't consider float as a charging stage, so would call the Rogue a 2-stage charger. Others, like Bogart, do, so they call their controller a 4-stage. A bit confusing ...
EDIT: oops, I see BFL has already answered.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
