BFL13
Feb 11, 2017Explorer II
JRRNeiklot wrote:
Charger goes to 15.2 or so. I have everything straightened out now. How often should I charge to this 15.2 threshold? I'm getting 12.8 volts at 100% SoC.
Thanks.
And thank you to everyone who offered advice. I'm learning as I go.
What is the model etc of that charger--link please.
Meanwhile you could just ignore P1 etc until your solar is installed and just use the Tri as is out of the box--as I have done since I got mine six years ago.
That way, you can keep track of your battery charging with the Tri and not get all tangled up in what that particular charger does.
Wait, and set it all up when you have the controller or charger that you will be using in the future.
