Searching_Ut
Feb 26, 2017Explorer
For P2 on the trimetric, the recommended setting for Trojan flooded batts is 2, which equates to two percent of the value you entered into P3, which should be 360 based on the type of batteries you have. The Trimetric will do the calculations internally as to how many amps that equates to. I didn't see where you indicated which charger you have so I don't have any inputs for your settings there. Does your charger give a state of charge indication as well?
