Searching_Ut
Feb 26, 2017Explorer
JRRNeiklot wrote:
Ah, thanks. I changed it back to 2. I have a Renogy Tracer 4210 40 Amp MPPT Charge Controller. It does not have a state of charge indicator.
Now I recommend you go with the previous advise and do a hydrometer check on your batteries to determine if they are actually fully charged or not. I'm not sure why your charge voltage isn't up to 14.8 volts with the batteries accepting less than 2 amps given the settings you're saying it's set at. When you said setpoint of 14.8 was that for your solar charger or something you entered into the trimetric?
