jplante4's avatar
jplante4
Explorer II
May 22, 2017
Trip Report
I thought I'd post the result of our first trip with the new battery/solar setup. If you missed the first thread on this, this spring I added 4 new 6v Interstate 225 AH batteries (along with 2 new AGM starter batteries - Geez), another 100 watts of solar for a total of 200 watts, and a cheap PWM controller.
The trip was to Assateague NP and a new KOA in Chincoteague. We also did 2 nights at Harvest Hosts locations, so it was 5 nights dry camping and 5 nights with full hookups.
With full sun at Assateague, the solar kept up with the loads during the day and we ran the generator for an hour at the end of the day to top off the batteries. At this point the voltage was down to 12.7. Any big morning loads (microwave, hair dryer) required the generator, which is what I suspected. Our last night of dry camping was cloudy, so I ran the genny a little longer in the evening. Chincoteague was the only place where we needed the air conditioning and we were hooked up there. Assateague was great with a nice breeze. I imagine July and August are not like that.
In general, I'm happy with the setup, but I can see how doubling the solar would help. I'm still getting a funny voltage problem when there's no load on the batteries which I need to figure out. But my fear of toasting the control board on the fridge was unfounded. Full sun, no load the battery voltage as reported by the solar controller (which appears to be reading a half volt high) if 15.9. I haven't had the chance to measure the actual battery voltage in this condition yet. More to come on that.
I kept a very close eye on the water levels in the batteries and it looks like I used just over a quart in the 10 days.
The purpose of spending $1000 on batteries and solar was to be able to dry camp without running the generator several times a day. I feel I've done this now and the length of a dry camp stay will be limited by tank size rather than power.
  • jplante4 wrote:
    2oldman wrote:
    12.7 is a full charge.
    That's 12.7 on the controller, 12.3 at the batteries. The consensus from the last thread was that the charge wires to the batteries are undersized and that accounts for the difference.
    A 0.4 volt difference in a simple voltage reading? No, that's not because of wire size. I have a digital vm hooked up with telephone wire and it's right on.
    Perhaps I'm misunderstanding what you're saying. You mean the controller is charging at 12.7? Perhaps you need a better quality controller. That doesn't sound right at all.
    That's 12.7 on the controller, 12.3 at the batteries. The consensus from the last thread was that the charge wires to the batteries are undersized and that accounts for the difference. I'm going to remedy that, as well as installing a shutoff from the panels to the controller. There's no "off" mode on the controller. Seems silly to me.
  • Thank you.
    I only wish more folks would take a bit of time and construct a report about their system. This is positively the most realistic feedback for folks considering panels (or anything else for that matter).
    ...t the voltage was down to 12.7. Any big morning loads (microwave, hair dryer) required the generator, which is what I suspected.
    Full sun, no load the battery voltage as reported by the solar controller (which appears to be reading a half volt high) if 15.9. I haven't had the chance to measure the actual battery voltage in this condition yet..
    More solar would be good.
    12.7 is a full charge. Generator? Bummer! Get 2 more 6v and you won't need to do that. But you will need more solar.
    I'd check that 15.9 carefully. Sounds like the controller is going into equalize. I wouldn't want that.
    Good job!
