pianotuna
Sep 25, 2015Nomad III
Hi landyacht,
I have four--but next time the battery bank is hungry I'll check to see if two will accept more than 46 amps.
Documentation on mine makes no mention of a 23 amp limit. That really makes no sense to me as the only limitation should be internal resistance, which is always pretty much low in AGM.
As far as discharge rates go, I've pushed them to 160 amps in load support mode via the Magnum inverter.
Maybe PM Mr. Wizard to see if he knows--he has been using his for about 50 months.
The lifeline may be the better choice for you.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
