j-d
Sep 29, 2016Explorer II
It takes Model and Spec Codes plus a Manual to adequately troubleshoot. I know that for the 4KY, a slightly larger genset built along the same concept as the 28 series, the Oil Switch was discontinued after a certain Spec Code. People with later Spec gensets spend a lot of time looking for a device that's not there.
Just for what it's worth, we had a gummed carb on our 4KY. I could start it, and it would carry a load until the load dropped off. For example, I could start it, turn the A/C on Max Cold, and it'd run that A/C for hours. You could hang meat or ship flowers in that coach. As soon as I reduced the thermostat setting so the compressor dropped out and the load became only the fan, genset would quit and not want to run again till it had cooled.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
