macattack_ga's avatar
macattack_ga
Troubleshooting an Onan 2800
We recently acquired a 1995 Roadtrek Popular 210 (chevy) with an Onan 2800 Microlite.
Generator cranks and runs very well. Makes power. Runs smoothly. But after about 3min it shuts down. It will start right up again and run for 10-20sec and then shut down again with just a little choke (actuated by my finger on the control arm).
I've disconnected the remote start/stop controller.... same issue.
Disconnected any electrical load.
Plenty of oil.
Fuel filter is good.
Fuel pump seems to work. It pumps fuel when I disconnected the hose... maybe it quits after a few minutes.
Planning to rig up another fuel pump to verify.
When shuts down, it doesn't bog/surge like it is running out of fuel... it sounds like it was switched off.
If it's not the fuel pump I'm guessing it's an issue with the ignition coil.
Any other thoughts?
Thanks!
Mac
  • You say you have plenty of oil but is the sensor bad. Try bypassing the low oil sensor.
  • Low oil sensor is my thought. I had this happen to me. Try disconcerting the sensor. If it runs with it disconnected replace sensor, If still happens not sure were to point you. But i think this is all it will be.
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 21, 2025
