3_tons
Mar 27, 2019Explorer III
Chris Bryant wrote:
I can count on one hand the number of failed compressors I’ve run in to in 30 years of servicing them.
I dare not doubt that - yet if the meter findings are significantly askew, it might indicate the presence of a leaky winding (or even a pending failure) which could explain why *running amps (via clamp-on meter) exceed mfg’s published running amps...This would naturally assume that the **caps (or in some cases, the soft-start device) are in good shape. Just saying...
*Note that running amps involve compressor and fan.
**Warning: the caps contain very high voltage and should only be serviced by a qualified technician...
3 tons
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
