sayoung
Mar 29, 2019Explorer
RLS7201 wrote:Wild Bill 888 wrote:Take the readings from the wire leads & not the compressor terminals, the current from the meter can under certain conditions, example grounded, blow the terminals off the compressor shooting out very acidic oil & refrigerant .
How does a meter with a AA or 9v battery blow the terminals off? Is there a new hydrogen/oxygen refrigerant ?
Taking measurements off the leads may cause you to replace a good compressor due to a bad lead or bad connection.
And while your questioning his electrical expertise, I'll question his refrigerant/oil expertise. It's not acidic.
Richard
ACID
Just keep touching your leads on the terminals of compressors with grounded windings,
It will happen. I don't have much HVAC experience, just a little shy of 40 years .
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
