- Travelin2ExplorerThe electrode, as you know, needs to be quite close to the burner. 3/16 inch or so. The burner itself needs to be well grounded for the spark to happen. Check with your multimeter to see that the burner is well grounded. If there is a lot of rust or loose connections, that could be the cause. If grounding is questionable you can route a ground wire there and see if the spark will jump to it.
Does the gas valve open and emit gass for a few seconds when you first turn it on? If so, then you should be able to light by match just to see if that part of the control board is functioning. - Ralph_CramdenExplorer IIThe OEM igniter boards are known to **** out and usually do so between the 2nd and 3rd year. If the board turns out to be the culprit forget about the OEM board and go HERE .
- pismopeteExplorerI have the same water heater and had the same problem. I took some very fine sandpaper and polished the little rod that the spark jumps to and problem solved. Good luck.
- howardwheelerExplorerThanks. Then I’ll try the switch first then the thermostats. I’ll try to get off easy. The control and junction boxes aren’t readily accessible.
- BFL13Explorer IIThere were two different thermostats, one for 120 and the other for 12v
There were two reset buttons on the outside under a black rubber cover, one for each ISTR.
My owner's manual (went with the 5er to new owner) had the schematics in it. - howardwheelerExplorerThis wiring diagram does not show the electric heating element. Do you know if the same thermostat that seems first in line after the switch also controls the electric element? If so, I can assume the thermostat is not the problem since the electric element does come on.
- BFL13Explorer IIISTR the light was separate as in this drawing, but it was in the 5er we had, so memory fading.
https://www.google.ca/search?q=suburban+rv+water+heater+parts+diagram&sa=X&biw=1024&bih=422&tbm=isch&source=iu&ictx=1&fir=V-LSdqIpY8ZFeM%253A%252CZB80fQSDAy1WzM%252C_&usg=AI4_-kQWBFXF2_wsuHCdYj8G6m3Gkt3ulA&ved=2ahUKEwjO1e2H-7bgAhVVLX0KHbWQD_kQ9QEwBXoECAYQDg#imgrc=V-LSdqIpY8ZFeM: - howardwheelerExplorerThe switch does turn the red light on and off. Could it still be the switch? I’ll get out to the trailer and check. That sure would be the easiest to fix!
- BFL13Explorer IIWith mine it was the switch itself. You can take it out and by-pass the switch joining the wires to see if that works. Next in line after the switch is a small control board (plastic cover)
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
