computermonkey's avatar
Jun 11, 2018
Truck Camper adding inverter
Would like to hear from people on there recent experience on adding an inverter.
My goal. To power a 1350 watt microwave for 10 minutes at max power.
I have two group 27 batteries and a 120 watt solar panel. Wanting to add at least a 3000 watt pure sine inverter.
Would like to know if someone has tried this kind of set up before?
What inverter did you use?
How long could this set up run a microwave?
Appreciate your time and help.
  • Freep wrote:
    I have a some questions for those who have added inverters to their TCs.
    A. Where did you put the inverter and why?
    B. What would you do differently?
    C. Is it worth getting an inverter with a builtin transfer relay switch?
    D. What inverters should I absolutely avoid?
    A: Under the bathroom sink, because that's the only place it would fit and because it's very near the battery bank. Cables are less then 2 feet long
    B: Nothing
    C: Yes, I think so, because it drastically simplifies installation, because all power goes through inverter (from shorepower) meaning I didn't have to add another transfer switch or complicate the AC wiring by adding "inverter only" outlets.
    D: I will say what inverters I "will / would" buy: Xantrex, Magnum, Outback Power. I'd also go true sine wave if buying another inverter.
    Wiring details for Inverter and Battery monitor
    Xantrex Prosine 2.0 Inverter
  • jplante4 wrote:
    Mover from Truck Campers
    I don't think this thread should have been moved to tech issues. Truck campers have more specific space requirements for inverters.
  • deltabravo wrote:
    (A. Where did you put the inverter and why? )
    Thanks.
    My battery compartment is under the bathroom sink. As I look at it, I realize that if I wire an inverter directly to the batteries I will be bypassing my battery bypass switch. So when I flip that switch I'll still have the inverter connected.
    It looks like I'm probably going to have to mount the inverter to the underside of the kitchen counter.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
