Old_Islander
Jul 25, 2019Explorer
Rvpapa wrote:
3/4 x3/4 x 1/8 angle iron. Notch the ends so it is supported on the framing with the flange supporting that questionable joining practice. Drill and countersink the vertical flange (lower than centerline) for suitable flat head screws to drive in parallel to the floor sheet. Before final assembly, dampen the wood with a sprayer bottle of water and get some urethane glue in the split. Practice dry fit up first as the final fit will be much easier.
Art.
That is a great idea re the angle iron, Art... Will look at the 'hole' tomorrow, and think that thru... Thanks...!!!
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
