Old_Islander
Jul 25, 2019Explorer
BFL13 wrote:
I don't quite understand what the photo is showing, but the slide-in camper we had came with a step up to the bed, which was the top of the battery box, which was about a foot wide. The water pump was in the same box with the batteries,
Anyway, assuming you have removed the cover for the water pump etc, so not showing, can you make a new water pump cover that comes back farther to cover the "hole" too, and step on that? Might have to cut the cupboard door bottom short on the right, move a hinge, but you can still reach down to get stuff.
You're right, there was a step-up box there that was removed before the first photo -- should have taken one before doing that. Below is the camper floor plan showing the step -- the hand-drawn red box is the 23" x 23" hole I've cut out. So building a box over it would solve the problem, but it would be a nuisance stepping up on it to access the fridge and it would likely impair the slider moving in. I sure wish I could, though... :)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
