BFL13
Jul 25, 2019Explorer II
For lots more work, you could make room above the water tank for the under-floor repair, by lowering the tank.
The bottom of the camper in the truck box might sit on three strips of wood or whatever, so the actual bottom of the basement could be cut and replaced lower so the tank is a bit lower, and the camper would still go in the truck up on the strips of wood same as now.
(We also had a 5er, so the rails for its hitch had to be cleared to slide in our camper. That was done by having some 2 x 4s in the box. Some camper guys do that anyway, so there is clearance above the bed rails to get things in under the camper overhang at the sides.
