pianotuna
Mar 12, 2014Nomad III
Hi,
Yes, 48 volts is better. For stationary banks, where they don't travel with you, it is a no brainer. For traveling banks it requires twice as many jars. 8 are a lot harder to find cargo capacity and a good location than 4.
To use 48 or 24 a good dc to dc converter may be the best route to go, rather than redoing all the electronics in the RV. 2oldman uses 24 volts and has such a converter.
I found room for seven batteries, which is another reason I stayed with 12 volt jars.
06GTORR wrote:
Thank you guys for all the help after I get every mounted up and fitted I'll find out what I can fit the l16 would be tight but I think it will be worth it . For the added life
I've thought about 24volt but have been told 48 is where it's at for bigger battery stores
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
