MEXICOWANDERER
Mar 12, 2014Explorer
ALTERNATIVE charging sources are much more expensive as voltage increases from 12 volts. With a generator and charger or solar panels this is not a challenge. But running down a highway with an alternator sitting on it's butt is perhaps the main drawback to higher voltage. I had two alternators on my Crown conversion. When both were engaged fully, you could see the fuel pump link arm move a quarter inch! This is back when a "real-deal" on Kyocera panels meant 290 dollars for 51 watts. Times sure have changed.
Try to PROTECT those L16's as much as possible from road shock.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
