drsteve
Dec 12, 2018Explorer
rhagfo wrote:ggardne2 wrote:
Comments below ... the standard breaker with no options should work ... it might be best to remove the breaker and take it to an electrical supply, they should be able to find an equivalent match to your existing breaker.
Partno. QO120GFI -- Base GFI Breaker, No Options
Mini CB - QO - 20A - 1P - 120V - 10kA - Plug-in - GFI
Partno. QO120GFI35 -- Higher temp rating
Mini CB - QO - 20A - 1P - 120V - 10kA - Plug-in - GFI - 50Deg
Partno. QO120GFIBCP -- Commercial Packaging
Mini CB - QO - 20A - 1P - 120V - 10kA - Plug-in - GFI - CP
Partno. QO120GFICP -- Commerical Packaging
Partno. QO120GFISP -- Short Pigtail
Partno. QO120VHGFI 22kA breaker
Mini CB - QO - 20A - 1P - 120V - 22kA - Plug-in - GFI
Replacing a GFI with a standard breaker without making the first outlet a pass through GFI outlet is a violation of electrical code, and makes for a very unsafe situation.
The standard breaker they are referring to is a GFI breaker.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
