groundhogy's avatar
groundhogy
Trying to identify a Breaker in my electric panel...
Hi,
I have a '91 airstream and on the lower breaker position is a GFI, ground fault breaker.
So the identifying marks on the actual breaker are:
Type Q0 60/75 deg CWIRE
1 Pole Class A 120vac
Square D AL/CU #8-#14
Interrupting rating 10,000 amps
Max. RMS sym. 120 vac
series 2
So its a Square D...
I went on the internet and did a bunch of searching, and, I found a breaker part number that might be it. But Im not sure. The first part number in the list seems to be a base part number and the ones after that seem to be breakers with special options. I have no idea what the options mean.
Partno. QO120GFI
Mini CB - QO - 20A - 1P - 120V - 10kA - Plug-in - GFI
Partno. QO120GFI35
Mini CB - QO - 20A - 1P - 120V - 10kA - Plug-in - GFI - 50Deg
Partno. QO120GFIBCP
Mini CB - QO - 20A - 1P - 120V - 10kA - Plug-in - GFI - CP
Partno. QO120GFICP
Partno. QO120GFISP
Partno. QO120VHGFI
Mini CB - QO - 20A - 1P - 120V - 22kA - Plug-in - GFI
  • rhagfo's avatar
    rhagfo
    Explorer III
    ggardne2 wrote:
    Comments below ... the standard breaker with no options should work ... it might be best to remove the breaker and take it to an electrical supply, they should be able to find an equivalent match to your existing breaker.
    Partno. QO120GFI -- Base GFI Breaker, No Options
    Partno. QO120GFI35 -- Higher temp rating
    Partno. QO120GFIBCP -- Commercial Packaging
    Partno. QO120GFICP -- Commerical Packaging
    Partno. QO120GFISP -- Short Pigtail
    Partno. QO120VHGFI 22kA breaker
    Replacing a GFI with a standard breaker without making the first outlet a pass through GFI outlet is a violation of electrical code, and makes for a very unsafe situation.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    If the breaier is a GFCI (has test button) I would only replace with another GFCI. there is a reason they use those.
  • Check your local Home Depot or Lowes I think they both carry Square D breakers and panels. 84 Lumber may even carry them. Take it out, take a picture or take it with you and match it up.
  • Comments below ... the standard breaker with no options should work ... it might be best to remove the breaker and take it to an electrical supply, they should be able to find an equivalent match to your existing breaker.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
