wa8yxm
Feb 23, 2015Explorer III
Too much too small wire feeding the outlet.. The voltage is dropping under load.
you need to find a stronger wire in the bedroom.....
QUESTION, is there a slide out for the bed? and if so what is the make of the slide system,, Accu-Slice there will be a controller, likely either above the slide or below it a piece of fascia covers the area.. Tap the power to that, that lead can hauld hte freight just fine.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 29, 2026
