djbroughton
Feb 23, 2015Explorer
wa8yxm wrote:
Too much too small wire feeding the outlet.. The voltage is dropping under load.
you need to find a stronger wire in the bedroom.....
QUESTION, is there a slide out for the bed? and if so what is the make of the slide system,, Accu-Slice there will be a controller, likely either above the slide or below it a piece of fascia covers the area.. Tap the power to that, that lead can hauld hte freight just fine.
But the new connection read about 12.5 v? I was never strong on Ohms law.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 29, 2026
