accsys
Feb 24, 2015Explorer
Most 12V lights only pull an amp or two at most so the wire for that light is much too small to carry the 8 to 10 amps or more required for your inverter to feed the CPAP. Get an extension cord (at least 14 gauge), cut the A/C plug/sockets off and run it from the batteries to the cig light. Just use the white and black wires and you will not need the ground (green) wire in the ext. cord but do put a 15 amp fuse in the line for protection.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 29, 2026
